This was my first project using the coolant system. This is the cheap (~$12.00) misters off of eBay. I found a seller in the States & didn't have to wait a month for them to be delivered. The slip in air line fitting is 8 mm which is practically identical to 5/16". I had to add the ball valve. It's a simple siphon system that actually works quite well.
I have added one of these to the project list. I have some mystery steel that is 1.5 OD. Would that be big enough to make a fly cutter for a RF30 mill clone? Also would a .500 OD be big enough for the shaft that fits in the collet. Why I ask is I like to use my .500 and .375 collets whenever possible. Keeps me from having to change out collets.
