- Sep 30, 2012
- 521
Problem: I need to open up a bore from rought 1" to 1.125 using my mill and a boring head. I have two boring heads, one is 1/2" and the other is 3/4". I also have a 5/8" boring bar I will have to use because it is long enough.
Now then, I was thinking of making a temporary bushing out of 6061 to adapt the 5/8" bar to fit the 3/4" boring head. I will need to drill then bore the bushing as I don't have a 5/8" reamer. Simple enought but the kicker is the bushing will have to have a 3/8" hole (appx.) drilled thru the side of the bushing so the grub screw that tightens on the boring bar will line up. Hope that makes sense.
The question is how would you drill this hole in the side without distorting the bushing as it is a very tight fit. I know you can buy the adapters, but they are horrible expensive, especially for a one time operation.
I have a 3/4 Aloris boring bar but it is too long and I don't want to shorten it.
Sorry for the long post. Any suggestions will be appreciated.
Thanks, Bob
Thanks, Bob
