Well, we've started cleaning my Remac milling machine and it is quite a job, removing and getting rid of many years' oil, chips and all other sorts of gunk. I'm actually very tempted to take it apart completely, clean it thoroughly, paint strip it and do a proper job with a complete reconditioning. At the moment, that will have to wait though, as I'm to excited to start working on it.
I have two questions, please:
From what I can determine by looking at the insides, after having removed the bed, the machine only has power feed on the X-axis - both ways. There is one knob and gear that puzzles me a bit though. My guess is that its function might be to take up backlash on the feed screw, but I'm not sure. It only turns about 1/4 of a turn in both directions before it becomes really tight.
The second question is about the spring loaded plunger, that supplies oil to the power feed gears, bed ways, etc. I worked it a few times, but there's no oil coming out the copper lines. Could it be that the oil is supplied under pressure, by some sort of oil pump down in the feed gearbox, when the machine is running, by simply pulling the plunger?
Below are a few pictures showing everything described above. Thanks in advance.
