- Jan 7, 2016
- 3,279
About 32 years ago, I built a drum sander for woodworking. It has served me well over the years and sanded a lot of wood, but it needed some maintenance done on it. One of the maintenance items that need attention is the pillow block bearings. They are starting to get noisy and should be replaced.
The bearings are pillow block Browning Bearings with PB220 on the casting and A108 on the bearing itself. It also has an "N - D" on the bearing, which I am unsure if that is relevant. The shaft diameter is 1.5". I would like to just replace the bearing insert so that I can maintain the centerline of the drum in relation to the bed, although a small variance could be dealt with.
Since I purchased them at a "Fleet Farm", I know that these were "agricultural" bearings. Should I step up to a better bearing, and if so, how do I find an insert bearing that I know will fit? I know that there are sources out there to cross reference, but the Browning bearing company was swallowed up by Regal Rexnord I believe. I should point out that Regal bearings are not cheap apparently and yes, cost is a consideration. I would also like to find a solution that does not require modification to the sander. I have a lot of house trim to sand and cannot afford the time to re-engineer the machine.
I did spend some time today truing up the drum in my lathe. I am excited to get it back up and running.
TIA
TIA
