Hi...
After ongoing issues with my mini-mill, I finally identified the spindle bearings as the culprit. The manual describes the two spindle bearings as identical 6206-RS types, but the actual bearings in the mill are a 6206-RZ upper and a 7206-AC lower. While the upper bearing is sealed, the lower is not. The "AC" designation apparently means "Angular Contact". I called the manufacturer, Big Dog Metal Works in California, and they confirm that the actual bearings in my mill are what is currently being supplied in new product. While finding 6206-RS is very simple, I'm having trouble locating a U.S. source for 7206-AC, though I have certainly not yet exhausted all options.
1. Can anyone describe what the bearing numbers mean?
2. It makes no sense to me that the lower bearing is not sealed. It would then require periodic regreasing, which would require disassembly of the mill to the point where the spindle is pulled. Any thoughts or comments on this?
3. Has anyone replaced the bearings in the Real Bull mini-mill before, and if so, what bearings did you use?
4. Can anyone explain the relevance of the "angular contact" designation on the lower bearing?
Many thanks for any information...
