Wow talk about a surprise... I found the gears I need to replace in the Martin Sprocket and Gear catalog. These are on the reverse chuck... specifically the 27 and 30 tooth gears. Well the 30 tooth is $36 the 27 tooth is $314. I about fell out. Is this normal? The 30 is a stock gear while the 27 is not but is listed in the charts. These are 16DP 20 deg with 7/8" center hole.
Any body got a better solution? Thanks in advance.
-John Barton
-John Barton
