We just got a Bridgeport series 2 milling machine. The motor took a long time to spin up and the variable drive rattled. When I pulled it the motor, the shaft key way is trashed and the lower shaft has some wear. The bottom half of the drive pulley has a little wear but I think new bushings may fix it. Has any one ever welded a motor shaft to build it up and machine it back to original specs. where could I find an affordable motor. (4 hp 230 v 3 ph)
I have quite a bit of experience welding parts up and machining or simply grinding them back to specs but have never tried it on some thing as precise and balanced as a long motor shaft. Any help would be appreciated.
Also if any one knows a good source for parts on this machine.
thanks, Gyro-Dawg.
thanks, Gyro-Dawg.
