I scoured the internet for a couple of days before I found the correct diagram. Read article after article talking about start windings etc. I assumed L1 was the black/hot, and later learned that in fact it wasn’t. L1 is the White wire. Green of course is ground and L2 is the Black Wire. The catch is (or at least was with mine) that you have to put a jumper wire from one side of the switch to the other, and you’ll see that in the diagrams and explanations. The various drum switches are marginally different but the concepts are the same. However, and to be clear, I AM NOT AN ELECTRICIAN so take what I’m saying with as nothing more than “2nd hand info”. With that said these switches most times have a wiring diagram on the inside of the housing, have you checked there? I’m just up at my cottage or I’d copy the notes I made and forward them to you. A bit of reading though and you should be fine.
Cheers
Derek
