- Dec 13, 2016
- 142
Replacing my Clausing 100 mk3 cross slide screw. Was going to try turning a new cross slide screw but did not have a follower.
Tom McNett at Clausing said the crossslide screw no longer available. Decided to retro the 4800 series cross slide screw part# Q-352 on my lathe. Ordered the Q-352 from Clausing for $189. There was a 2 to 3 week lead time. Received the screw which also include the nut and gear.
Replacing my 100 mk3 crossslide with a crossslide from a Clausing 200 lathe. It is the same casting as the 4800 but does not have the recess milled for the taper attachment or chip guard. Have already rough milled a 0.750 x 0.125” recess.
Need to know the following:
1. Recess width
2. Recess depth
3. Distance between two screw holes
4. Distance between screw hole and edge of recess
5. Assume holes are 1/4 UNC threads
Appreciate any information,
Bob G.
1. Recess width
2. Recess depth
Bob G.
