Need ER32 nut dimensions
martik777
Apr 19, 2011
1,138
It might be best to measure the nuts you have or will be using. AFAIK there's no standard for the slots. I'd hate to make a wrench based on someone's dimensions & then possibly find out that it doesn't fit my nuts well.
I have various ER40 nuts both in bearing type & standard type from various manufacturers and they all differ slightly in width & depth. I've even had to modify some of my wrenches to fit my bearing nuts.
But aside from all that, I don't have any ER32 stuff. Hopefully a number of people could post dimensions from different nuts & you can average it.
In case anyone is interested, Fastenal is selling Techniks INC ER32 collets for $12.49 each.
Google is your friend. Search "er32 dimensions", use image search to narrow it down.
  • Here you go:
  • ER32 Collet Nut holds all ER32 collets
  • Made from alloy steel hardened to 54 - 56rc
  • Precision ground ID thread and taper
  • ER32 Collet Nut has an internal thread of M40 X 1.5 pitch
  • Outside diameter is 1.968 inches (50mm)
  • Outside has spanner notches for tightening
  • ER32-Wrench works on this collet nut
  • Internal cam removes collet when unscrewed
  • Black oxide finish
  • MariTool Part# ER32 NUT
  • https://www.maritool.com/Tool-Holde...3_30_31/p48/ER32-COLLET-NUT/product_info.html
