- Feb 2, 2013
- 3,629
very strange pitch, but i'm glad you are able to get taps and dies
It is then a thread used by a manufacturer for their own reasons, it is not a mystery merely uncommon.I measured this thread with a Mitutoyo thread pitch gauge. It is definitely not an 8-32. The 30 TPI pitch gauge is a perfect fit to the screw.
Nothing else comes close.
One may produce threaded products of any combination that you desire, published thread standards are guidelines not laws, the thread police will not turn up to arrest you.
I have been guilty of making parts with uncommon threads just to confuse people in the future for the simple reason that I can.
Producing a 3/8"-15 or 17 thread will cause someone considerable confusion down the road.
This is where people confuse TPI with the lead of the thread.I actually have a couple of 3/8-18 stainless steel studs that I made. I started with 4" cap head screws , cutting the heads off and threading. The threads came out perfect and I was pleased with the work until I tried to run a nut on them. DOH!
However, if you really want to confuse them cut a 3/8-12, 2 start thread. It will measure 24 tpi but good luck finding a nut to fit. Left hand threads also serve to confuse.
The XKE also required the entire front end tube frame forward of the firewall removed to replace the starter. An all day job, 8 hours flat rate. A friend who worked at a BMC dealer showed up hung over one morning to such a job, peeled back the carpet, cut a hole in the sheet metal, removed and replaced the starter, pop riveted a new piece of metal over the hole, hid the sheet metal work with undercoating, replaced the carpeting, and got his 8 hour flat rate job done in under 3 hours.The reason I bought the tap is that someone tried to brute force some of the hardware with, I imagine, an 8-32. Fortunately they cleaned
up fine.
I feel your pain on the British cars: I worked on them some myself. They were a real pain at times. The worst job I remember was
changing the clutch in an XKE: I had to damn near dismantle the car to get that clutch out.
