Need Help On Radius/angle Dresser
Sandia
Sep 30, 2012
521
I am looking at purchasing a dresser for my Harig surface grinder. Found out they are pretty expensive. On searching ebay the Yuasa brand shows up frequently but are $350 up for a decent one. Some of the offshore brands are less.
What do you guys use and recommend. I hate to spend $350 plus for a dresser to find out one of the cheaper Chinese brands will work just as well, such as the Phase II, etc.
Thanks, Bob
I've had one of the cheap import (Yuasa Clone) ones for years. I don't use it often but it's never let me down.
Give it time,... I got a excellent condition Yuasa 500-001 for $235 delivered from eBay.
Add a search you follow for "radius angle dresser" and give it time one will come up.
I made a radius dresser than mounts in my spin index ficture. For angles I use angle blocks against an angle plate and manually slide my block mounted diamond dresser on the angle block. Good enough for my purposes, don't know about yours.
Ron
