I need some ideas on this project. I haven't machined much in my life but I'm trying to do this project myself if at all possible. I have a shaft and pulley setup out of my p.o.s. vertical mill that is at the end of its life. I've attached a few pictures but they may not do this justice.
The keyway is slopped out on both pieces. The shaft on the gear that mates with the pulley setup is worn down and the fit is very sloppy without having the key installed. I need to build up the shaft on the gear and I will have to bore the center of the pulley.
Major obstacle that I'm not skilled on (mainly the whole project) is making the keyway in the pulley setup. It is not a through hole to use an arbor press and a broach.
I wanted to make a new shaft for the gear but it looks like that was machined all in one piece so will probably have to build up. It was a quick inspection so will have to look further at that to make sure the gear won't press off.
