- Aug 26, 2014
- 132
Hello Everyone,
I need to resharpen some tool bits as discussed above to the same or close to the same kind of sharpness I can get with HSS.
I can grind HSS on my HF 39797 grinder with included wheels no problem, but when I try to grind HSS on the new Silicon Carbide wheels, it's slow, and very…finicky. It's hard to remove enough material to get a nice hollow ground edge.
I'm trying to get the same kind of hollow ground on my carbide bits with the Silicon Carbide wheels (60 and 150) but though I can tell by using a marker on the surface that the grinder is removing material, I can't seem to get the shape I want.
Do I need to practice more?
Also, I am thinking about getting a Diamond wheel like this:
http://www.mcmaster.com/#diamond-grinding-wheels/=uvqnqb
And I'm wondering if that would work for my purpose. I've heard that you shouldn't grind freehand with a diamond wheel because it takes off too much material. That might be what I need. I have steady hands, but I'm wondering where to go next.
Any thoughts?
Pierre
Any thoughts?
Pierre
