I am trying to get a ideal 310 die to screw into a 7/8-14 adapter so that i could use those dies in my dillon 550 reloader and not have to buy new dies. The ideal 310 adapter inside thread is supposed to be 5/8-30. Well i have a 5/8-30 tap and i redrilled the hole with a 19/32 drill bit...then retapped for 5/8-30 and the inside diam is still too small. I dont get it.
The od is 7/8-14 on the adapter and works just fine with the dillon head. It is the inside diameter that has me confused. It is supposed to be 5/8-30. The id on the adapter mics at .590" the tap od mics at .625" the od on the die mics at .645"
Yah, you are right. I have 9 of those dies in 3 different calibers and was hoping i could just make 9 adapters on my lathe and save 300 dollars by not having to buy 3 different sets of dies at 7/8-14 .
