- Nov 9, 2013
- 790
When I bought my Logan 820 about 3 weeks ago, it came with a big wooden box of "stuff". I could ID most of it, but there were a couple things I wasn't sure about.
There are two cast iron disks that look like raw lathe chuck backing plate castings, and I wanted to see if you thought the same, or if they're something completely different. There is a "3" cast into one, and a "4" cast into the other, so I'm guessing maybe the pattern had four pieces per flask and these are two of them. All the other numbers match on both pieces.
There was another piece that was even more unusual. I'm guessing it was part of a large tool post grinder. What do you think?
It has "SC23" cast into one end, and the handwheel moves the arbor horizontally. It's hard to see, but there are bearings on each end of the shaft.
Thanks for your help!
GG
GG
