I have a working Teco 7300cv suppling my SBL16. it's currently set up with two remote momentary switches, in a three wire PNP, configuration(I haven't cut in a FWD/REV switch yet).
All is good and it works as expected.
I now want to wire in an older Estop that I have, but the Teco manual is a little thin with the details. My Estop is a momentary with NO and NC contacts. I know I can wire it, using the NC contacts, in series with my current stop switch. I'd rather use the separate estop inputs in the Teco, so I can adjust the spin down.
How is it wired? Like the stop switch, but using the NO contacts, 24V on one side and the other side wired to either contact A or B?
..or is it wired across contacts A and B?
Will a momentary work at all?
..or...?
TIA,
Eric
..or...?
TIA,
Eric
