- Aug 7, 2013
- 655
Many of you may remember this thread. http://www.hobby-machinist.com/showthread.php/17869-Sewing-machine-RPM-reduction
Well, when I pulled the motor off, I didn't label the wiring. Shame on me! At the time, I thought I could remember.......... "thought" being the key word here!
I searched Singer's website and came up empty. I know there are guys on here that know their stuff with motors.
Here are a few pics of the setup.
I'm missing the wiring diagram for the motor.
Motor wiring. The solid wires come from the switch/cap. (upper left)
I'm guessing that I need to check what wires have continuity. Right?
Pic of the switch and cap. The power comes in on the right two screws from the cord.
Here are the questions of the thread.
Is this a start or run cap? (doesn't really matter, I know it works and I just want to know.)
How do I figure out what wires go to what on the motor end? I guessed on a bandsaw motor and the magic smoke escaped! I was really mad and upset at myself for that!
The motor will be wired for 110.
The rest of the tread is non-wiring related.
Thought I'd add a pic of the set screws I put in the hub I made.
Here's another shot of the idler pulley (aka timing belt tensioner from a car) I had to add because of the larger pulley that was put on the top. The belt would have rubbed on the slot in the table if it wasn't there.
I'm excited to get this powered up to see how slow it will go. Slipping the clutch gets old! I'm hoping that I can keep the clutch engaged and walk around what ever it is I'm sewing.
Thanks for looking!
Thanks for looking!
