Hey guys,
Tonight while trying out my dividing head using the dividing plates for the first time instead of using the degree marks to cut 4 equally spaced flats on a 3.5” piece of steel, it didn’t not come out equally spaced. 3 of the flats look ok but the 4th is way off. I used the correct plate and the correct number of revolutions and holes per half turn. In my case it was a plate A 20 hole and it states to crank the handle 20 + 10/20 to get 4 equally spaced flats. However, this was not the case. I am stumped, each time I try and start a 0 degrees and turn the handle it always ends up short of where I started???? Something doesn’t seem right, I have watched many videos and haven’t seen this problem. I started with the rotary table set on “0” just for reference and none of the flats line up with the degree marking I was using for reference, in my case 0, 90, 180, 270, 360. I have no clue what’s going on. Can somebody please help...
