Hey fellows I have a Huanyang 1.5 ,wired to a 1750 1hp it runs fine on 60hz,but when I try to run it on 40hz or anything lower it will shut off and display shows OA,also on 60 hz it pull 1.7 amp,if I run it on 40 hz it pulls 7amps,why does it pull so many amps set at lower hz?,motor is good took it and had it checked, also can't figure out what ter. to wire a pod. The worst manual ever saw!
Thanks
Thanks
