- Nov 9, 2013
- 790
I'm almost finished building my radius turning tool, and it is time to mount the carbide insert. I'll need to drill and tap a hole to mount it, but have not had any luck finding any reference to the screw size or pitch.
The insert I'll be using is a VCMT 160404-PM5 made by Walter in Germany. The screws that I use to mount my TCMT 32.51 inserts fit perfectly, but I don't have a metric thread pitch gauge that is small enough to measure it. I measured the outside diameter of the screw (on the threads) at 3.85mm. Can someone educate me so I can order the proper tap? Thank you!
GG
GG
