- Oct 17, 2018
- 922
I hope this is the right forum for this issue. I have an Atlas/Craftsman lathe that I'm restoring. The wiring from the power cord just hooks up directly to the contacts on the motor. It just hangs there, putting a constant strain on the contacts. It appears the plate that covered this area is missing. I'd like to wire this up so the power cord comes in to some sort of junction box/terminal box, then out to the motor and switch.
In the image, the wire with the red terminal and the white wire at top are from the power cord. The wire hooked to the twist connect is to the switch and the other wires come from the switch. The original owner just used power cord for all the wires, so there are extra wires.
I thought I might place a household j-box under the motor. I can't just make a plate to cover the wiring area on the motor because the wires and connectors stick up too far.
Does anyone have pictures of what their machine's electrical hook-ups look like I could use for reference? Any suggestions as to what a solution could be? Thanks!
