- Dec 17, 2012
- 745
I'm back from a week long sort of :drink2: county fair.
I made on the fly some general purpose panels/frames using "some" lath (8 meters every panel!) joined like a capital squared A, with another couple of perpendicular lath as foot.
Every feet is joined to the vertical strip like an upside down T, with a screwed L plate to keep the parts together.
Even if pretty coarse these frames were very appreciated by all the stands as a fast way to hang posters and other things.
This frame will give you an idea of the shape:
http://www.displays2go.com/P-10990/...x-40-Posters?st=Category&sid=2284&position=17
This is a sub-optimal solution for a good storage and moving of these panels, because fixed foot are too bulky.
I need a solution to make the foot easily removable… :think1:
The vertical part is 30×40 mm and the feet is 40×20 mm, and of course everything is made with the less expensive (but still expensive!!!) wood I found around.
Do you have suggestions for a way to make a robust joint which can be assembled without tools in a very short time by totally unskilled helpers?
