Need to find or build a steady rest
Investigator
H-M Supporter - Gold Member
Jun 8, 2016
603
I have a 12" Logan 2537 turret lathe. I don't have a steady rest for it, and I have a need for one. I have found expensive examples on Ebay, and honestly don't want to pay that much if I can help it. My thought is to find one from another lathe that would fit, or make my own.
So, 2 questions;
1.) what other brands of steady rests will fit on a Logan 12"?
2.) what options do I have for building one from scratch? Does it have to be steel? Is aluminum Ok? Maybe a silly question, what about making one out of wood?
Basically I'm looking for ideas.
Wood turners often make steady rests out of wood. I think this will end up being larger than one made from metal, but it may work.
An article I wrote for my local wood turning club to give you some idea if you want to pursue a wooden steady rest. For wood turning the diameters of the projects are often larger than for metal. If I made a version for metal, I would use the bearings from the inline skate wheels instead of the entire wheel to enable smaller diameter stock.
Making wooden steady rest for wood lathe
Interesting idea. I wonder what the forces would be turning a 1.625"OD tube 8" long. Would the wood handle it? Even if I had to make it 2" thick, if it works, it works.
Wood should work. I've seen wood used for much heavier work than you describe.
I build two, a smaller 11' version for my Rockwell to make a cannon. I later made a much larger one to hold a spider for threading odd shaped actions.
The first one has brass pads on the supports, the later big one got roller bearings. The work is fairly straight forward, but a mill will be a must to do a proper job. I can take pictures today if you need some inspiration.....
Roller steady rests are fine, until a chip gets caught and dings up your work; I prefer the old stand by, cast iron as it wears well and does not gall. I have made several steady rests; one had a capacity of about 20", it was for a 24" swing Nebel lathe, it was made of 1 1/2" steel plate, burnt to shape by an electric eye burning machine and was hinged in the usual manner; the latest one is for a 9" Monarch cone pulley drive 'teens era lathe, I made a pattern for it and had it cast in iron, along with a follow rest and large and small faceplates.
Photos would be very much appreciated.
A steady rest from a slightly smaller lathe should be fairly easy to raise up to the correct height and adapt to the bed of your lathe
"Roller steady rests are fine, until a chip gets caught and dings up your work;
John,
thanks for the info on using bearings on the steady rest. I was just about to modify mine with bearings. Your caution has
made me seriously rethink (unthink) my idea.
Here are two examples on You Tube of home-made steady rests:
