- Sep 14, 2014
- 438
Greetings all. I'm a new Creality Ender 6 Owner. Set up December 26th. Delayed purchasing a 3D printer because I hoped for a non-project. Didn't work out that way. I did a quick search of the group for "Heat" but nothing came up. Hoping someone may have seen this before and can help.
I've found 3 ways to set the heat for the nozzle and bed for printing and it takes about 90 seconds to get to the selected temps.
- [Temp] Automatic (Generic PLT)
- [Temp] Manual set nozzle and bed.
- [Print] Select file, [Adjust], change the temperatures from "0" to, example, the generic PLA 195/40 and Return.
- ( Can't find a setting to turn off auto-numbering !@#$ or not use code).
- All three result in a message "Heating . . . " and the target temperatures being shown as the selection. Yes, I've double checked all the cables are seated. Because the thermistor appears to be reading the temps during the heat up, and shows the temperatures falling using option #3 above until the settings are changed from "0" I suspect it's not the thermistor.
- Ideas?
- TIA
