Some of you know that I recently installed a tpac tool 2 axis dro. After I finished i took a Mitutoyo dial indication and checked it against what the dro was telling me. My problem is that when I go to cut say. 1mm it’s generally always larger than that. I usually bring the insert up to the material, touch off then zero out the zero. I take my calipers , measure the workpiece. Say the workpiece measures 22.75mm , I start the lathe move up 0.75 and cut the Material. What I’m finding is that is always greater than what the dro says , even though it dead nuts on the dial indicator. My dro allows a offset from -1.5 to l.5. This doesn’t seem appropriate as my dro is reading correctly. Am I missing something
