I successfully installed the Turnado on my PM-1022. First impressions are very favorable. First cut was just a radius in the end of a some steel bar. Actually much easier than wood lathe turning. The cutter is very easy to control. I drilled four holes (100 mm spacing) in the mounting plate so I could turn the platform either direction. After a lot of measuring, I cut the standoffs to 35.26 mm. Amazingly (given my skill level), all four standoffs came out the same length.
