- Feb 2, 2014
- 112
It was purchased new welder at the weekend. It was a Reli 200, at good price and maximum 200 amps. Variable height and div. peculiarities. Tried it a little to some tasks, and it was difficult to stop! I welded absolutely beautiful, like putting on thick paint with a artist brush.
But it had not wheel suspension on it. So then I had to make. It went okay, but I'll make a better grip for better control of the "vehicle". The carriage also got hold of the gas bottle. Mison or CO2.
I did not have loose wheel, so I decided to make two of 3 mm aluminum plate and turn them round in the lathe. The outer edge of the rim was built on with aluminum strips which were welded together to form a ring. The hub, two aluminiumrods with 10 mm holes in it.
They should have 2-3 mm rubber tires, but so far, gaffa tape tire.
It provides extreme low profile: 20/2 R3,5 - 10 profile! Take that!
Which tires should I use rubber from a hose to the tire, I obtain?
ramma: :thinking:
And extreme low profile. Then I can weld in cornering high speed ... )
To fasten the welder I turned four guide pins that go Up in the rubber feet of the appliance.
As for fixing gas bottle I made a circular ring of 1 mm plate, which was welded to the end of the frame / wagon. I took the job of adapting it down in the recess at the end. And with 2 mm clearance I have room to paint and duct tape top. When should the "sit" alone.
ramma: :thinking:
