- Sep 29, 2013
- 130
Hi G4003G owners. If anyone is interested, here are the results of my spindle/gearbox break-in. These are the results only from another post.
First I did the break-in with oil in the gearbox measuring bearing temperatures, rotational speed, and gearbox noise. After the break-in was complete, I put new oil and 16oz, one bottle, of Power Punch in the gearbox. The gearbox noise was then measured again. Below shows the test setups and the resulting data.
Gearbox Noise Level Measurement.
Added 3 pieces of reflective tape to chuck for checking speed with laser-tach. Divided readings by 3.
Inboard Bearing Temperature Measurement.
Outboard Bearing Temperature Measurement.
Motor Pulley Bearing Temperature
__________________________________________________ ___________________________________________
_____________________________________________________________________________________________
So it appears, in my case, the Power Punch essentially made no difference in gearbox noise, if anything, maybe a little louder. I wonder If I added too much and should have gone with only 8oz. Regardless, the gearbox isn't too noisy and I am pretty happy with it so far.
I thought the laser-tach speed readings were pretty interesting. According to the manual for the tach, the accuracy is, +-0.05% +1 Digit. Therefore, at say 1000 rpm, the tach should accurately read between 997 and 1003 rpm. The nameplate on the motor says 1720 rpm. I measured the motor speed at 1793 rpm. A difference of 73 motor rpm does not account for the difference in measured and set spindle speed. I was going to count the number of gear teeth inside the gearbox and do the math to see if the numbers would jive, but I ran out of time. Ok, yeah, I was too lazy to do it!
Bob J
G4003G Headstock Break-In | ||||||||
Chevron GST 32 Oil - Equivalent to Mobil DTE Light | ||||||||
No Power Punch | ||||||||
10/29/2013 | ||||||||
Running | Outboard | Inboard | Motor | |||||
Speed | Time | Bearing | Bearing | Pulley | Headstock | Tach | ||
RPM | Direction | Minutes | Temp F | Temp F | Bearing Temp F | Noise dBA | RPM | |
70 | Fwd | 20 | 58 | 56 | 86 | 68 | 85 | |
70 | Rev | 20 | 61 | 58 | 96 | 67 | 85 | |
200 | Fwd | 20 | 67 | 61 | 101 | 72 | 236 | |
200 | Rev | 20 | 69 | 64 | 102 | 71 | 236 | |
220 | Fwd | 20 | 71 | 65 | 103 | 68 | 255 | |
220 | Rev | 20 | 71 | 66 | 102 | 67 | 255 | |
270 | Fwd | 20 | 73 | 68 | 102 | 74 | 307 | |
270 | Rev | 20 | 76 | 70 | 103 | 72 | 307 | |
360 | Fwd | 20 | 80 | 72 | 104 | 70 | 421 | |
360 | Rev | 20 | 81 | 74 | 104 | 70 | 421 | |
600 | Fwd | 20 | 89 | 77 | 104 | 73 | 708 | |
600 | Rev | 20 | 92 | 79 | 105 | 74 | 708 | |
800 | Fwd | 20 | 97 | 81 | 104 | 76 | 920 | |
800 | Rev | 20 | 99 | 85 | 103 | 76 | 920 | |
1000 | Fwd | 20 | 113 | 87 | 105 | 77 | 1167 | |
1000 | Rev | 20 | 111 | 90 | 106 | 79 | 1167 | |
1400 | Fwd | 20 | 122 | 93 | 106 | 80 | 1511 | |
1400 | Rev | 20 | 126 | 94 | 109 | 78 | 1511 |
Noise Comparison Before and After Power Punch | |||||
10/29/2013 | |||||
Without PP | With PP | Noise | |||
Speed | Headstock | Headstock | Difference dBA | ||
RPM | Direction | Noise dBA | Noise dBA | With PP | |
70 | Fwd | 68 | 67 | -1 | |
70 | Rev | 67 | 66 | -1 | |
200 | Fwd | 72 | 70 | -2 | |
200 | Rev | 71 | 71 | 0 | |
220 | Fwd | 68 | 69 | 1 | |
220 | Rev | 67 | 68 | 1 | |
270 | Fwd | 74 | 74 | 0 | |
270 | Rev | 72 | 76 | 4 | |
360 | Fwd | 70 | 71 | 1 | |
360 | Rev | 70 | 72 | 2 | |
600 | Fwd | 73 | 75 | 2 | |
600 | Rev | 74 | 77 | 3 | |
800 | Fwd | 76 | 75 | -1 | |
800 | Rev | 76 | 77 | 1 | |
1000 | Fwd | 77 | 75 | -2 | |
1000 | Rev | 79 | 79 | 0 | |
1400 | Fwd | 80 | 78 | -2 | |
1400 | Rev | 78 | 80 | -2 |
Bob J
