Back in the day, BC (before computers) I did some carpentry work as a sort of sideline. The fellow I worked with(for?) was big on pressure treated decks. When I started a job, I would buy a WalMart special (cheap!) circular saw. Usually less than $40. And a pack or two of, again-cheap, blades, six to a pack. By the time a job was finished, the saw bearings would be at or approaching worn out. I would offer the saw to the customer. If they didn't want it,(quite often) I would take the saw and the old blades home.
A carbide tipped blade cuts fine until a few of the tips break off. Then they were used for rough work and "old work" where I would cut old lumber or might hit a nail. When a few more tips broke off and I could cut a board faster with a torch, I would grab one of the old saws, put the blade on backwards, and use it to cut sheet metal, usually roofing. Heavy commercial grade stuff, not the Home Depot special that is one step above aluminum foil. By the time a blade was beyond that sort of work, I would cut it down with a torch and make a blade for wife's sidewalk edger. Of course, that didn't last very long. So I would cut it down again and make a 5/8 inch fender washer and hang it on a nail in the barn. Ya never know when one will come in handy.
The whole point here is that nothing is ever thrown away. Even the kitchen garbage is composted. A milling cutter breaks off too far up to be resharpened. That leaves a tool steel pin a couple of inches long. If nothing else, it might become a pin for my tractor. Or a bearing hub. Or . . .
