- Dec 17, 2012
- 630
I have not been happy with the saw arbors that I had. The R8 arbor left the blade too close to the spindle, the one I had made before was too short and needed too much space below the blade. I was watching one of Tom Lipton's videos and saw a design I liked better so I decided to make a new one.
The shank is 3/4 in diameter and the head is about 1-1/4 diameter. Material is 12L14 steel. 1/4-20 SHCS for clamping. Counterbored 3/8in.
The arbor can take up to at least 1/4 in thick slitting saws. The clamping piece is 1" diameter and the end is bored a bit deeper. It is a pretty close fit to the bore and to the blades. I have to put it in pretty carefully because there is hardly any slop. I can counter sink it a bit more (well, I could actually take it about 1/2 in deeper) and take the clamping piece a bit thinner to get more clearance below the blade but I decided I would live with it a while before making any modifications.
Here shows the clearance below the blade.
The shank will let me adjust it in the collet if I need to have a bit more space.
This is with a 3/16 blade and you can see the R8 version behind it. The R8 version left about 1/4 inch below the spindle which got really crowded.
