- Nov 4, 2011
- 124
I've been using compressed air only for a job I do repeatedly. I'd like to try mist cooling. I bought some KoolMist and the "OriGlam Mist Coolant Lubrication Spray System" from Amazon - all hooked up and working. If it matters - I cut .075 thick 6061 with an 1/8" bit turning 5000 RPM (my mill's max) - the shape of the work (and my skill level with MACH3) are such that I can't do it in multiple depth passes so I cut all the way through in 1 pass. I cut at F2 (inches).
Any advice? How much mist is needed? How do you clean up the mess afterward? I know this is water-soluble oil but if any is left around am I going to end up with any rust on my machine?
Thanks
Thanks
