Yes I am going to number the dials. I have a new set of stamps on the way. I still have to make the compound dial while I wait.
I made a new shorter and slightly smaller knob for the power crossfeed. I also changed the spring for a slightly softer one so that it easier to pull out. When I get a chance I am planning to convert to a lever action.
I must say that the most handy tool to have while rebuilding an old lathe is another working lathe.
I too built the lever style control. It was from the Project in Metal books. Worked great. The cross feed engagement knob can be reduced in length if needed. I left mine long in case I had to remove the lever assy and still use the lathe. Note the larger dial on the cross feed. Lever in the down position - power cross feed is engaged. About 3/8" of travel is all that is required.
Pierre
They are just two 2" disks 1/2" thick with a .99 hole. Each is tapped for an 8/32 screw. The stationary piece gets a set screw to hold it to the nose (?) and the dial gets a set screw to hold it to the old dial. Simple and easy. And I had a piece of 2" stock with a .9 hole to start with . It used to be something else ???
