- Jan 22, 2020
- 197
going to have a flash powerpac
solenoids are 24vdc hence the gel batterys 2x12vdc in series
I tried swinging to ac 230 for pump motor, but even with large cap it would not fire so went back to 3 ph.415ac
I have also a 4 way hand valve oil to two rams, one vertical one horizontal, one to radial motor with flow control 0 to 110 revs for wheeling, stretching
i bought two power pacs off of auction 280 the pair were off of a cat ferry to control water jets, thy have alu tanks , the last test stamped on the valve block 350 bar
i think to make the table top 30mm 5083 alu, reason is i need holes for pins and although i have an old magnetic drill I do not have drills to suit
I especially like doing electrical work and ss plumbing which is far cheaper that quality hyd hose
