Tony Wells link=topic=3019.msg21226#msg21226 date=1312740483 said:
Slip fit in this case is likely no more than 0.0002. The clearances in the bearings themselves are also part of the necessary calculations. The problem and difficulty here is in temperature coefficients. The spindle will grow when it reaches operating temperature, but that generally comes from the bearings, which also change size as they run. The idea is to strike a compromise with as low a clearance as possible when cold, and not too little clearance when warm to allow an oil film. When things warm up, and everything is sized theoretically perfectly, all there is room for is oil.....no clearance other than that. The bearing will "shrink" onto the spindle and there will be no clearance there.
Kind of like old tube radios.....they drift until temperature stabilized, but until then they are still usable.
