Thanks !Nice work!
I'm sure that it will slow down in a little bit, I'm trying to figure out what to do with the power down feed gears!My only complaint is that you are moving too fast!
I have machines that have been waiting a decade for that kinda of attention.
Yeah, is kind of a bummer with that worm gear damaged!Too bad on the power feed problem.
Even though yours is older, does it have roughly the same style power down feed unit?Mine is older but in perfect condition and I love that power feed.
It's been a while since I had the cover off, but the outside of the unit looks the same and the front panel also.AGCB97
Well then maybe it's time for a maintenance inspection.It's been a while since I had the cover off
DougWell then maybe it's time for a maintenance inspection.
I realize this is a big favor to ask, but would it be possible for you to check inside the power down feed unit & see if there happens to be a part# visible on the large worm-gear. I'm also curious if the original gear is brass/bronze or cast-iron?
Doug
Thanks Aaron, that would be great!I think I can do that, but it won't be till later in the week. Mine is located in my annex which is unheated, and we have a few nasty days coming up.
I can understand that!Mine is located in my annex which is unheated
