A
Andre
Forum Guest
Register Today
While tearing the Cub Cadet mower apart to sharpen the blades, I noticed on top of the deck one of the idler pulleys had an issue. It's mounted on a bearing, and the bearing self destructed! None of the balls are round anymore, the cage was torn up and sticking outside the bearing!
The bolt was so rusted I had to resort to "Sparky" measures. It took an eternity to grind off the head of the bolt, which was a mildly hardened grade 5 bolt. Indicated with three hash marks on top.
After the pulley was off, it was clear it was never made to be fixed, the pulley was sheet metal and welded together with the bearing inside.
Here is the pulley bearing before any work has been done, notice all the galling on the bottom of the shaft where its been spinning ever since the bearing gave up the ghost.
In order to remove that bearing, I have to turn that lip down or else it would block my effort to push it through.
Here it's after being turned:
Notice that pronounced RUST RING!!! I tried using my HF 1-ton arbor press with short cheater bar to push it out....not even close. It's been sitting with penetrating oil since last night, tomorrow I'll hit it with a torch and see if it pops free.
