- Sep 25, 2013
- 222
Happy Thanksgiving to all - I was checking my Grizz milling machine for tram and found it a few thou off which was easily reset, but got curious about the nod direction [ Mine is a 3616 which has no adjustment for nod] and I found it was .005 in out across a 9 in span. In order to correct this I will need to shim between the head and column if this is too much to live with. Just need some feedback from more experienced than me to see if it needs to be fixed. I do plan to remove the head and overarm assembly from the column and check the mating surfaces to see what they look like before I do anything else. Thanks in advance == Jack
