[4]
Nooby threading question
[3]
[10] Like what you see?
turner421
Newbie
Jan 27, 2019
5
I have seen video's and heard guys say to angle your compound to 30 degrees when cutting a 60 degree thread. Do I still need to do this considering I bought an indexable threading tool? thanks
Technical Ted
H-M Supporter - Gold Member
Nov 5, 2016
798
Yes, but I set mine to 29 degrees. You want the back side of the threading tool to just "touch" the side of the thread as you feed in and take cuts.
Ted
jbobb1
H-M Platinum Supporter ($50)
Dec 14, 2018
141
Here's something to ponder!
T Bredehoft
Dec 27, 2014
2,984
If you hit 30º exactly you are making a perfect thread. if you happen to be a bit over, well, it's not so good, that surface (on the right) will be stepped. If you aim at 29.5º and miss by a tiny bit, it won't matter. I believe this is the true argument for 29 1/2º. The EXACT angle doesn't matter, just so it isn't over 30º.
ttabbal
H-M Supporter - Silver Member
Jun 12, 2017
886
I just go straight in. Makes the bit a form tool, but it works and it means I don't have to worry about the compound. Which is nice since I don't usually have it installed anyway. :)
Technical Ted
Nov 5, 2016
798
There are as many different ways of doing things as there are machinist, but I cut my teeth on South Bend's book on How to run a lathe and here is what that says on this subject. There is more than one way to skin a cat... but this has worked well for me over the years on the lathes that I have run.
Ted
290480
jbobb1
Dec 14, 2018
141
I was taught the same thing and have lived by that rule for almost 40 years. I've cut more threads than I can remember, and it never failed me.
benmychree
John York
Jun 7, 2013
3,330
Subtract one from that camp; From the time that I took machine shop in HS from a teacher that apprenticed at Mare Island Navy yard, and taught in the apprentice school, and was subsequently apprenticed in a large local shop, I never knew of any fellow machinist since that did the 29deg. thing. The only place that I hear about 29deg is on this forum; I am now going on 75 years ago, and can say that 30 degrees works just fine, with no incidence of steps on the backside of the thread. So far as feeding straight in, except for very fine pitches, it is not a good plan, as the chips coming from both sides of the cut interfere with each other at the center, and can cause finish problems. going straight in can cause problems with remembering dial readings.
As an aside, the Europeans have the custom of feeding straight in with the cross feed, but feeding in with the compound from right to left with each succeeding cut, this told me by a German guy in our shop, Karl Groneck.
savarin
Aug 22, 2012
2,182
Since I removed my top slide and replaced it with a solid plinth I have to go straight it.
I slightly round the point of the tool do the thread bottom isnt a sharp "V"
For my use this has been a simple process for all the threads I've cut to date BUT 2mm between crests has been the largest thread I
[6]
[5] [7]
