Off Topic impossible
GK1918
Nov 21, 2010
1,602
OT but is electrical. I got a IH TD15 Dozer probably one of the last that starts on gas then to diesel. So the last time I forgot
to put a bucket over the muffler and some rain got in there. Then we got some water in the gas (holds about 1 gal.) ok still no start.
my kid pulled the plugs and I sand blasted them. He put a new 12vt coil. Then I went back to the shop. Next thing I know my kid
comes running all burnt up for a extinguisher. Well he's alright just singed up a little, dozer was yellow now its black. Kid said no 2
cyl exploded when he started threading the spark plug in thus catching the gas tank fire.
The impossible question HOW? Engine is coil points system not "magneto"- Ign Off, Kill switch off, gas shut off valve off.
weather around 60* grass kind of due'ey (wet) , the kid dont smoke.
so dont the weather rule out static charge from his fingers. He allready put one plug in, it was cyl 2 that blew right at him. He is sitting
on a steel track, so his butts grounded.
One for the books tottally impossible. Just can - not happen. And my kids a DFD fireman, been to fire academy knows about high tension
line fires and such.
any thoughts gentlemen.......
pic when it was yellow not now
Glad he's OK.
... All it takes is a spark.
Ray
Maybe a carburetor bowl full of gas? I can't imagine, unless gas was around the dozer from working on it?
Bernie
If there was somehow power to the coil. I remember getting shocked a few times by points systems. If the points are in just the right spot, just about to open, and then the distributor is bumped or maybe a sticky centrifugal advance that then shifts (it's under spring pressure). And then it would have to have the rotor pointed at the cylinder being worked on 50/50 chance of that on a 2 cylinder.
Not sure if a 2 cylinder starter motor would even have centrifugal advance.
Can't imagine a spark with out power to the coil.
Hard to imagine static making a spark.
Could have just been static; dry air and a good walk across the shop is all it takes. Glad he's alright. Makes me glad we finally got a fire extinguisher for the shop.
I also think that somehow the coil had a built up charge which released at the wrong time. Obviously that cylinder had to be at TDC, but how did the points get power? I'm sure you already checked out the wiring. Maybe a bad ignition switch that did not fully open the contacts.
Glad your son is alright! How old is he?
That is a weird one! I hope he's not holding out on something he did!
The only way I can think of this happening is this. The cylinder has gas in it. The spark plug is laid by the spark plug hole connected to the spark plug wire. Engine is turned over to visually check for spark. Gas blows out of the hole, spark plug sparks igniting the gas.
I lite my hands on fire with a snowmobile doing this. Thankfully, I wasn't burned very bad.
The only way there can be spark to a spark plug is if the points are closed to supply current to the primary windings of the coil. When the points open, the power to the primary windings is cut off. However, around those windings is something called EMF. Electrical Magnetic Force. The EMF collapses into the secondary winding and thus the spark you see at the plug. All of that being said to say that unless there was a capacitor included in the circuit, I don't see where the current came from.
OH, I'd suggest a few flappers on the exhaust. Such a cheap solution to a possible expensive problem.
Something doesn't add up.
I have the same type engine on my Farmall MD except mine has a magneto.
In my life I have never seen a spark created from installing a spark plug.
I have never seen anyone install a plug with the plug wire on.
Unless the starting lever was set to start mode the third valve is closed and the cup is isolated from the cylinder so gas could not be pushed out by the engine turning over.
There is no "storage" cap on the coil so unless the ignition is turned on there is no magnetic field for the points to control.
The only way I see for the gas tank to catch fire (at least on mine) is if it was leaking gas or if the cap was off and somehow the fumes ignited.
I'm glad your boy is alright but I suspect there is more to the story than what he told you.
The distributor cap is real close to the carburetor so if the drain was leaking or he drained the bowl it would put gas in harms way for a loose spark from a disconnected plug wire if he bumped the engine over.
On mine the plugs are sparking even when in diesel mode IIRC.
The condenser in a points and condenser system holds a good charge.
Much horseplay in the shops I have worked in by charging up a condenser and tossing it someone to catch---it will shock the heck out of you.
I'll have to disagree.
The condenser is only about 0.2uF and it is there to keep the points from burning from PIV and the help with a touch of resonance of the coil.
At 0.2uf you can charge it to 12v and hook it up to a coil and it will not be able to charge the coil from lack of current storage capacity.
Unless you have thin skin or a cut you won't get electrocuted from 12v.
Whatever condensers were being thrown around were charged way higher than 12v.
