- Dec 13, 2012
- 466
I don't know about you but, I can never be sure the oil is getting past the little spring loaded balls in the oil ports. I know that some squeezes out but not sure if
any actually make it beyond the ball.
I've come come up with one solution that really works great. I can tell because when I gave a big squirt to the port in my compound over the screw, I got a lot
of it dripping out the bottom.
What I did was to take a small piece of material, brass in this case, and turned a counter bore just deep enough so that an o-ring just protruded beyond the surface.
Then just drilled the other end to press fit in the spout of my oil can. Works great!
The o-ring is - Buna-N O-Ring, AS568A Dash Number 104
Gary
Gary
