I have an late 70s/early 80s Victor 1630. That's what Victor told me based upon the S/N. It's early enough that it has a 5 HP motor, as opposed to the 7.5 HP versions. I've sourced several manuals for it online, though they are written in imperfect English. The manuals point to the areas that require oil/lubrication and also make recommendations for the type of oil to use, but they are vague on the quantity. While that wouldn't normally be an issue, I have one fill cup that has me wondering.
There is a fill cup on the right side of the gearbox (see right side of attached picture) which I believe supplies oil to several of the rotating shafts. I don't have a good idea of how much oil is required here and I can't see very well into the fill hole. The manual just says "fill it with oil gun". I have been adding oil in 250ml increments and have now added about 750 ml, which seems like a lot to me given the type of fill cup. None is leaking out anywhere, though.
Can anyone tell me roughly how much oil goes into this oil cup?
Many thanks,
Andrew
