I recently purchased a beaver knee mill. This machine is fitted with zerk fittings at every lubrication point.
I have seen this in the past and every machine had "use oil" tags or "grease only" tags on them.
I was always told, if in doubt use oil.
Thoughts?
Way lube for x,y,z is what I'm thinking. Not sure about the lead screws, ram slide or head angle ways.
This machine was definitely well greased when I pulled it apart.
Thoughts?
