I have a 30' x 60' shop, gable. All wood construction. 9' ceiling with open attic. Roof trusses are on 2' center. 6/12 pitch. The walls are insulated with fiberglass batts and OSB wall covering. I am not planning on putting any kind of sheetrock or wall board on the ceiling. The roof sheathing is OSB, asphalt shingle for roof covering. I can go with fiberglass batts or foam panels or open cell spray foam. The spray foam seems to be the best insulator? Your thoughts appreciated. Thanks
