R
Robert LaLonde
Forum Guest
Register Today
I recently picked up a second cheap import bench grinder. The plan is to take my slightly newer old import bench grinder and throw a couple brushes on it using the new to me older import bench grinder for tool grinding. I've made spacers for one wire wheel already and installed it, but have not replaced the outer wheel cover. The even spaced out 3/16 of an inch the wire brushes the inner cover a little bit. I'm debating removing the inner cover as well and running the wire brushes open wheel. That bothers me. I know it probably shouldn't, but it does. Other than throwing wires in unexpected directions when the brush wears out what other issues are there?
The other part of the plan is to make the table on my bench grinder stand longer, and mount the two grinders back to back with some space in between. I've got an extra cast iron table saw leaf that should do nicely.
