Optical Centre Punch
th62
Aug 22, 2014
316
I made this optical centre punch a while back, thought someone might bve interested.
The base is a piece of 40mm S/S. I bored the base 11mm for the lens, cut grooves on the side to accomodate O rings for a secure grip, dished the bottom to around 12mm then drilled a 5mm hole horizontally from the side into the dish to accomodate a 5mm LED. The whole thing was then mirror polished including the bore and the dish. The polished bore ensures a nice sliding fit for the lens keeping scratching to a minimum, the dish for better light refraction.
The lens I made from a piece of 12 mm acrylic rod which was turned down to 11 mm on the lower section, Then top and bottom of the rod were polished. I then scribed couple of rings at the top and cross hairs at the bottom.
The light consists of a switched AA battery box with a 5mm LED soldered to the end of the flying leads.
I also made two other light sources:
The first is powered by a 240/12v power supply. The positive lead was interrupted and a 470 ohm resistor soldered in place, heat shrink applied to the join and the plug at the end cut off and an LED soldered in it's place with a short piece of physio rubber shrunk over the top.
The second source is a small USB cable with the micro plug removed and a 5mm LED with 100 ohm resistor soldered in it's place and again a short piece of physio rubber applied over the top. This one can be powered by phone charger, tablet, power bank or any other 5 volt source.
Excellent for centre punching accurately, easy to make and a good toy to play with.
5.jpg 240.jpg bank.jpg P_20150503_091028.jpg P_20150503_092900.jpg P_20150503_094424.jpg P_20150503_094620.jpg P_20150503_094813.jpg tab.jpg
Nice. I have a Skidmore but wish it had a non skid pad for punching non ferrous metals. The magnet works
well though for steel. I'd buy one if it could be used with brass w/o slipping. Nice work.
