- Feb 1, 2015
- 9,609
O ring seals obviously are good for much longer times. O rings are used in plumbing valves, in hydraulic cylinders being examples. Seal life will depend on multiple factors. Material and operating temperature being two big ones. The chart you are looking at is for 257ºFI found this article very helpful. One of the oring I plan happens to have the same cross section as of the diagram:
Selecting the Correct O-Ring Seal Squeeze Ratio
One of the decisions equipment designers need to make when installing O-ring seals in their applications is how much the O-ring will be squeezed by...blog.parker.com
It looks like higher squeeze, the longer it lasts in term of keeping the elastic force. However, it may suffer pinching issue.
I am still a bit confused by this, if 25% squeeze, then it only lasts for 300 hours, which is 12.5 days. That's very low.
I believe you will find the Apple Rubber design guide to be more informative. https://www.applerubber.com/src/pdf/seal-design-guide.pdf
