- Sep 29, 2014
- 2,102
They are used when an OSHA visit is expected if you have a shop large enough to qualify, the inspector has a device that measures the pressure at the exit and if it is to high you will be fined. It has a crosshole drilled through it to relieve the pressure.
I do not recommend this but most have 1/8 NPT pipe threads at the outlet end and an easily available 1/8 pipe to 1/4 hose barb fitting makes an excellent full pressure nozzle, I did not tell you this however (-:
