- Feb 7, 2013
- 2,486
I have a lawn tracker that has a tire that unseats itself regularly. I put a ratchet strap around it, remove the valve stem, then apply compressed air. This seats the tire in no time. You have to be careful with the ratchet strap, because the inflating tire can put tremendous pressure on the strap, so I inflate until seated, then stop and reinstall the valve stem, then remove the strap. Only then do I finish inflating the tire.
Consider getting some of that black rubber tire sealant. I had a skid steer that would leak down regularly so bought a
can of bead sealant. You need to clean the rim well and also the tire bead surface before applying
the stuff. If you air up the offending tire and spray on some dish soap solution from an old spray bottle, it's
easy to find where the leak is and break the bead on that side for the repair. I'm a believer now.
