I don’t have Facebook, but I can tell you that I love my O/A setup. I bought Victor equipment, including both medium & large torches. I have a dedicated gas welding (includes brazing and cutting) cart, and this cart sees a *lot* of use.
Of course, make sure that your local welding supply will refill your gases if what you are looking at includes cylinders. I bought my own cylinders.
I like gas welding because it is more quiet than arc welding processes. I find gas welding to be more relaxing than arc welding processes because the work unfolds more slowly. For thin steel (e.g. less than .0625”), I am pretty much going to choose gas welding. For me, I can *setup* for gas welding much faster than for TIG.
I like brazing because there is no chance of blowing a hole in the steel. That means less stress on the operator! With brazing, you can just use Shade 5 and 6 safety glasses. No need to don a welding hood. This allows for a conversation if you have a buddy in the shop while you are brazing. I have brazed in a T-shirt & shorts, as well. You’re not going to weld wearing that!
What sort of flux are you planning on using? I use the bronze filler paste flux & filler rod below as they are designed to be used with one another:
Gasflux Type "B" Bronze Paste Flux 1lb steel brass bronze brazing
framebuildersupply.com
and
Gasflux C-04 nickel bronze rod - 1/16" - 1lb fillet braze steel
I use a liberal amount of flux, often to the point of some excess flux dripping on the welding table or floor.
If you have a big gap in your fit-up, you will have a rough time. A tight gap will save you money on bronze, as you can make a smaller fillet.
*If you apply too much heat you are going to have a bad time*. Get in, do some work and let ‘er cool down a fair amount before bringing the heat again.
I wait a long time (I try for overnight) before washing off the flux. I use hours of soaking in a 5 gallon bucket, warm (almost hot) water, elbow grease & dish soap if all of that doesn’t work. Make sure you get off 100% of the flux!
